Hello everyone new to iboats here. Recently I acquired a decent lil 1996 Johnson 48 spl.I did a compression check and the top cyl measured 135 and the bottom 132 I was happy
But thought I would give it some tlc since it is 17 years old. I rebuilt the carbs the fuel pump and the primer and replaced all fuel lines. I decided to remove the cylinder head for inspection just for **** and giggles and I found the head to be pitted pretty good especially below the bottom cylinder . The gasket had not failed but appeared it would have soon. I cleaned the surface and filled some of the major pitting with devcon. Then I sanded down on a flat surface and did the straight edge with feelers and found the surface to be flat. My questions #1) Is the head suitable for reuse based on pictures and description.
# 2) If not can I machine it down to remove the pitting? if so how far is max.
# 3) The third option I found is sum used heads on E-Bay But they are from earlier models ie 1992
and look exactly alike with the exception of the thermostat housing.
thanks for any advise.
