DamianJP
- Mar 25, 2008
- 612
Hey guys
Well I'm kinda bummed. I went to prep the area to put back the cylinder cover and when I was done I found that the bottom piston has play in it , top is solid with no play but looks like it might be worn too. You can see me move the bottom piston side to side with my fingers. Also when you rock the flywheel back and forth you can see the play too.
Compression was high on the bottom one which is weird. I think 120+ I forgot the exact number. Top one could not be taking because of a blown cylinderhead gasket letting Cyl 1 combustion into cooling area. Cylinder walls are both very smooth and no signs of 'bad' contact anywhere.
What should I do? Either I run it like it is or have to dig in and replace bearings and rings (Or do I need new pistons now too?) Money is tight and this is a real bummer. What are my options and how much would It cost to do the rebuild (Bearings and rings ect. Everything that should be replace while I was in the crankcase area?)
Thanks,
DamianJP
Thanks,
DamianJP
