piston orientation
raczekp1
hi.
I'm trying to rebuilt Johnson Evinrude 4.5 hp, 1980.
i forgot piston orientation in cylinder bore.
how to determinate which side i should put into?
maybe someone can explain how to figure out piston sides(which side goes to exhaust and which to suck port)
Re: piston orientation
The sloping side goes to the exhaust.----The " steep " deflector side goes to the intake ports.-----------Not sure what you mean by the " suck " port.----There is no suction there.--The fresh fuel comes in because of pressure in the crankcase !
Bosunsmate
yep steep side faces suck side so the fuel air entering hits it and goes to the top of the cylinder which helps push the exhaust down and out the other side. Unfortunately it pushes a bit too much so you always get a bit of unburnt fuel $$$$ going right through unused especially at idle
F_R
Universal rule of any crossflow two-stroke engine with domed pistons.
raczekp1
thamks so much for explenation.
best to all of you
gm280
best to all of you
Not sure about your engine, but I think if you put the pistons in 180 out, the head won't fit back on it...
boobie
On some motors they will work and others not. If you do get them to work backwards you'll get one hell of a rpm drop at WOT. Been there.
