Re: piston orientation
If you're looking at the "pistons," the "L" means loose side to remove the wrist pins...which there is no reason to remove. Still wondering why the pistons were removed? "Carb job" meaning carburator???? Or, "carb job" meaning removing built up carbon on the piston/rings/head??? If it's the later, there is an easier way with products like "seafoam," which do not require powerhead teardown.
Mas
