Pipe-mounted bunk bracket?
pastorbud
I’m re-building an old Gator brand twin axle trailer. The bunks are mounted on what Grok says are pipe-mounted brackets (reverse photo search). I want to replace a few that have rusted out. I have a vague memory of seeing them available on some trailer parts site, but can’t find them. Anybody know where to buy these?IMG_1817.jpeg
alldodge
Don't know of anyone which makes them out of pipe anymore, round is hard to keep in position with a set screw or clamp under heavier loads. I made a adjustable trailer using 1 inch threaded rod and weld a plate on top, used a nut to adjust
Could use galvanized pipe from the hardware store and a flange plate on top. Then bolt brackets to flange plate
