OK- here's the course of events:<br />After launching, my brother and I went to calibrate the motor steering. Put motor down and turned on finder and motor. <br />Finder worked fine. <br />Stepped on pedal and steering moved left and right. Stepped on motor run and nothing happened. <br />Checked to maked sure prop would turn, OK. <br />Went into setup mode for steering and motor still wouldn't run. <br />This was done with the finder, motor and foot pedal from you. <br />I had my pedal in the boat and changed and got the same results. Steering, sonar OK, no motor. <br />We gave up and went to a spot and anchored down to catfish. I left finder on to watch bottom with motor in water. About an hour later motor took off, on it's own with no one around, ramped up and down I had no control with speed wheel. Had to shut down motor to stop. <br />Turned it back on. It ramped up and down without touching anything then everything went off, No power what so ever. Checked inline fuse and it's OK. There was no power to anything after that.<br />Checked voltage when I got it home everything right on. 24 volts where it was supposed to be. <br />That's where it stands now.<br /><br /><br />Any ideas?<br /><br />UFM82
