It all started with a little oil leak so I decided to install a seal kit in my 1962 Evinrude. I found lots of metal hunks while in there. The pinion gear is shot along with a thrust washer, could use a new drive shaft also. Anyway, I need a pinion gear PN 0308692, anyone got one? I'll check Ebay next. I found a 50 hp unit with boat in the local paper for $1,000 maybe I should get that instead?
