Pickup Campers
JRJ
I'm thinking a camper would be a fun way to go and I could drag the boat. I just started looking and can see there are too many choices. I'm thinking 8' cab-over, any I should look at or stay away from. Thanks (wife is ok with it so far)
jimr
Re: Pickup Campers
Palomino makes a nice camper <br /> http://www.palominorv.com/palomino/default.htm <br /><br />I have an older hardsided popup and we love it for the most part. you are right there are a ton of choices you just have to decide what fits your needs.
JB
Re: Pickup Campers
Watch out for GVW, JRJ. Your tow rating will be reduced by the weight of the camper.
JRJ
Re: Pickup Campers
Thanks jimr for the link. How well does the soft materal hold up? I sure like the low profile and as JB points out, gotta be concerned with weight.
jimr
Re: Pickup Campers
our camper is a 1987 and it still is in great shape......we bought it this spring and I don't think the former owners ever took care of it, but it cleaned up great and is still water tight.
mike5097
Re: Pickup Campers
I have a 1993 Ford F250 diesel that I put a camper on and tow a 16' starcraft trihull with.<br />My observations:<br />Don't go over a 9.5 foot camper unless you want to start messing with expensive hitch extensions and the like. With my camper on I have to put a 14" extension on ($50 when I bought it two years ago), but it doubles as a step and makes no difference with hauling the boat. Of course the boat does not way that much.<br /><br />Whatever camper you buy get one with good quality electric jacks. That way when you get to your campsite you can dump the camper easily and head down to the ramp. The reason I mention this is that I have found that backing down a steep ramp with a big ol' camper blocking your view of the boat is a big pain in the petunia. I have one little spot where I can barely see the trailer to make sure I am straight. Having some help is great as is having an uncrowded ramp so you can take your time.<br /><br />The advice about watching your wieght is great. My trucks GVWR sticker says 8850 lbs, and when the camper is on, loaded with gear, water, and food, and the truck is fueled I am real close to that. Add the boat and I am right at the line or a little above. I do not know if the wieght of the boat matters or is it tongue wieght. All I know is that the truck handles great and I have never had a problem.<br /><br />As far as campers go I have a 1975 Caveman, and my brother has a new Lance. Mine cost $300.00 and his $20,000. Mine has character, his is pretty and looks like an apartment inside. The basic function of both is the same, but I am not constantly worrying about every little spec of dirt and scratch like he does. Not to mention his payments.<br />I am sure that the good folks on the truck camper forum of RVdotNET could give you great advice as to quality, insulation, construction differences of a wide variety of campers as well as how to outfit your truck for your particular application.<br /> RV forums <br />Good Luck!
JRJ
Re: Pickup Campers
Thanks mike5097 for the info and link. My GVWR is 8800# I will keep the weight in mind.
D
DJ
Guest
Re: Pickup Campers
JRJ,<br /><br />Not only is the weight a concern, but the frontal area also reduces your towing ability.<br /><br />I do not know what kind of truck you have but Ford makes an excellent towing guide that describes camper use also. Any dealer will have one.
JRJ
Re: Pickup Campers
Thanks DJ, its a 1994 3/4 ton Dodge diesel 4X4.
