Hi.
Thought I would introduce myself since I'm sure I'll be on here quite a bit as I get this 58 Johnson Seahorse 18 back up and running. It will power a Carolina Skiff J12 - hopefully better than my Merc 9.9.
I found the "Top Secret" files which proved helpful in removing the flywheel. The coils (very cracked) and spark plug wire connections are shot. So, I have all the parts to replace the coils, condensors, points, wires. I'm also going to clean the carb. Also got some new "o" rings for the pressure tank.
Anything else I should do or be aware of?
Regards.
Regards.
