Phantom motor serial number
Rickwoot
I have a 2002 mercury 150 but cannot find the serial number anywhere, OT513913. Does anyone have anything on this motor? Need timing information.
flyingscott
Why do you need to to!e your motor. Usually something that does.not change unless something catostrophic happens
stikboyy
You are looking for service manual 878079R01. I'll check if I have it at work tmmrw. And get some timing specs for you.
stikboyy
Found one at home
Idle speed/pickup timing 0-9 degrees ATDC
@cranking speed 22 degrees BTDC
Wide Open throttle RPM 16 degrees BTDC
