petrowski53
- Mar 28, 2009
- 42
Hey Guys,
My father just recently bought a new (to him) boat. It's a 1985 Thompson 185, with a Mercuriser 470 and Alpha One. He bought it from the original owner, who kept the boat inside his garage since new. The boat has seen minimal to no use over the past 20 years, so it is in pristine cosmetic condition. However, because the boat has sat indoors for so long, it does have several mechanical issues that need to be addressed before it is seaworthy again.
First and foremost, the boat will need a complete service. This basically means all new hoses (fuel and coolant), completely flush coolant, water pump kit, bellows, plugs, wires, and fuel system overhaul. I went though and rebuilt the Carburetor for him this weekend. The fuel pump diaphram was shot, so a new replacement pump has been ordered. The engine turns over fine and has (weak) spark.
While getting ready to tackle the ignition system, my father mentioned he'd like to convert to electronic ignition. I had considered it on my boat a few years back ('87 Thomson with the Mercruiser 2.5L), but never got around to it. I know there are basically two options. Either the Pertronix Ignitor (1146a) or Ignitor II (91146a) . There is only about a $30 difference in price, what are the advantages or cons of either? Also, can the ignitor II be used with the stock coil? I know the resistor wire usually must be replaced with a full 12v Source. I've just read a lot of conflicting information regarding the use of stock coils, especially the Ignitor II requiring the Flamethrower II coil (with the .6ohm resistance value).
Thanks guys. I'm sure this has been discussed before, but I'd like to get some more recent input on how these things are workin' out in your applications, especially if you have a 470.
