Re: Pertronix Ignition Conversion
The wiring runs as such: A full 12v comes into the the connector on the choke. The ballast wire is tied to that 12v lead inside the slide connector and runs reduced power to the coil. Cutting the ballast wire doesn't affect the choke because the power comes on the first wire. While it may be tempting to pull your 12v from this wire, but it never worked right for me. The engine would run fine for 30-45 seconds, then the pertronix would shut off, but was able to immediately restart. That's why I suggest just running a dedicated lead. If your boat is like mine and doesn't have a safety kill switch, this lead would be a good place to put one since cutting the power will kill the engine.<br /><br />My tach now stops reading past 3400rpm or so. I know I'm still turning the same R's because my GPS speed stayed the same and I was turning 4050 before the conversion.<br /><br />The conversion doesn't affect the interrupt switch on my Mercruiser, but requires a small "fix" to work with OMC units. I have built the "fix" to see if it helps the tach problem as all it does is filter the signal a bit. All the parts cost me ~$3 at Radio Shack and a few minutes of soldering.
