I have a aq120b volvo penta 4 cylinder. Bought the boat for a song. The dist was converted to a pertomix ignition. Points are gone. Dist was apart, wires, alt. etc. When i pull up Number 1 cylinder to tdc. The dist button is not aligning to number 1 post. No problem, turn dist till it points to it. Problem is the firing on the pertonix is not right. I pulled the coil wire, ever time the coil fired, i our a drop of paint on magnetic sleeve on dist shaft. Now have four points of fire. When i align the marks on the sleeve to the pertonix module, the rotor is pointin between two post. Seeems the rotor and , and coil should fire then, they dont. Am i doing something wrong, Please help. Just need to find number 1 to fire at tdc. Then i can finish up.
