permatex form a gasket on outdrive yes or no?
black sox
hi all,just bought my first boat 88 bayliner capri br 3.0 omc ,im doing maint on outdrive seals ,bellows ect.when i put outdrive back on should i put permatex form a gasket on both sides of gasket and flanges ? Im thinking yes to make a better seal,what do you all think?
Reinell-BRXL-191
Re: permatex form a gasket on outdrive yes or no?
It's what I use... has worked every time
projo198
Same here, I goop both sides. Helps hold the gasket in place as well.
wcasey5
I used the blue permatex, worked great, no leaks.
Idlespeedonly
I will be a little different here. I use the permatex aviation form a gasket. It never really dries, but it sure gets sticky. The thing I dont like about rtv is the removal of it. But ya know, I think either will work just fine.
MRS
Same here cleans up easier.
