CampionGuy
- Jun 24, 2007
- 58
Good Day iboaters,
Something is amiss in my 94 penta 4.3lGL. Starter wasn't engaging flywheel when power applied so I removed and disassembled it, it was a mess with the bendix frozen on the shaft. Cleaned everything, polished the shaft and reassembled. The ring gear slides freely on the drive shaft and returns to retracted position freely.
Here's my dilemma. The solenoid has a push rod on the end which sits idly in the retracted position. When the solenoid is intalled the rod hooks under the mechanism which actuates the ring gear on the shaft. In the idle position the bendix is fully extended to the position for engagement. Is the solenoid configured so when power is applied to it the push rod extends and retracts the bendix? Does the push rod rest on the top side of the actuator? When I disassembled it the rod was hooked under the actuator so I assumed that was the way it goes.
I hope this is clear enough to merit response.
Thanx in advance,
Doug
Thanx in advance,
Doug
