Hello all, I’m brand new to the forum and had a subject I can use some input on. I recently had an engine shutdown due to a high temp on the water. The thermostat was recently replaced as well as the raw water pump rebuilt within the last 15 hours. While at idle the temp got up around 220 and I had to shutdown the engine. We checked the inlet fins on the lower unit and no obstructions.
Since then I have pulled apart every hose in the cooling system and flushed, checked the clean out on the outdrive, as well as the raw water pump impeller, and thermostat. Water will run cleanly throughout the flush out with the engine off, and does push out through the exhaust with the engine running, I cannot get water to draw up the lower unit into the system at this point. Im sure this was my original issue while underway.
My last thought, and only component I haven’t troubleshot would be the Water Circulating Pump, item 19 in the diagram below. I don’t know if this is true but does the circulating pump help with drawing water up the outdrive fins in addition to the raw water pump? My next move is to pull this unit off and inspect, and for $200 I don’t mind swapping it, especially if that could be my fix.
Any help is greatly appreciated. Thanks
irculating Pump
irculating Pump
