Just got motor (200 Merc EFI, 1998 offshore)back from shop..had one cylinder re bored & others honed & replaced impeller...noticed that water temp of water coming from pee hole is hot, probably above 150 degrees... mechanic said this is normal, especially since type of work done on engine....does this sound right? Also, water pressure gauge is showing 12 lbs. @ 40000 rpm.
