Re: Pee Hole on a Merc '83 4hp 2 cyl
If it is anything like my '77 4 hp 2 cyl., there should be 2 columns ( 4 holes per column) of small holes on the top end of the lower unit, not too far below where it meets the lower cowl. They should be facing rear. So, in other words, if you are facing the prop you should be able to see the holes. They are above the water line.
