Pedestals
CBGale2
I posted this outside of here but nobody seems to have an opinion on the matter. Any of you guys had experience with pedestals seats? I found a set that are 2 3/8" posts and Im looking at 9" tall. The site I found them says they are for going less than 5mph. Most of the ones I checked after that said the same thing. Id rather not put my seats on boxes cause Id like to have the option to move them around for fishing. What do you think, ignore their silly recomendations?
fshngho
Re: Pedestals
My .02 cents: Mount the pedistal base secure and leave your pole with the base when you switch the seat. You said you are going to have a 9" pole so you won't need it in other locations. Make sure the seat is a good one, the back of most seats will not support you when you lean back. Have the bracket mounted on the bottom of the seat so you can move the seat to another pedistal base/pole. I would also suggest a pedistal that you can lock to prevent swiveling. Again, it is critical the base is mounted secure to prevent it ripping out of the floor if you lean or hit rough water/waves.
I use my pedistal seats in my bass boat and the poles are about 30", I would never ride in them when the gas motor is running. You could also build a base that would accept the seat bracket. Set the seat in that when needed and you could pick it up and move it when needed, kinda like a jon boat set up.
Dale
Expidia
Re: Pedestals
You wouldn't think a seat post used incorrectly could be deadly . . . but it can be!
I think you might be confusing the use of "any" seat used on the front deck where many newer boats come with seat post hole mounted on that bow deck.
When I bought my rig it had a big yellow sticker across the deck mount and the casting mount over the gas tank. Said not to use the forward or rear seat mounts over trolling speeds. It's actually illegal in some states to let someone sit in those seat positions while moving over 5 mph.
It's not a "silly" rule. If the bow hit a wave that person would be ejected. That post does not lock in either. Yet, my Captain's post came as on piece bolted to the floor and bolted to the seat.
Even if you used that one piece one up front the person upfront could still be ejected. Last year on Lake Champlain we got back to the dock and 20 police cars were at the Ticonderoga launch. Come to find out the next day a young child was riding up front in a bass boat. His experienced uncle was moving along and the kid went over the front and killed by the prop.
A 9 inch pole is not high. But any post with a passenger in the front is a recipe for disaster on the bow deck over 5 mph.
I swapped out my stock posts for Springfield air ride ones. I use the 13-20 inch travel version. But in a deep v rig. They make the 22-29 version that you can use up front too or with those little back seat support type seats you see on bass boats. For anyone interested in upgrading, they can be found for $85 each and they really smooth out the bumps especially in small aluminum's. Iboats might price match on these too. I looked into one of those little seats to use upfront for trolling and casting . . Those little seats are ridiculously over priced :eek:
Description off a site on the air ride posts: This power pedestal gives you an air cushion ride and lets you adjust the height by the touch of the control lever (base not included). Available: 13-1/2" to 20" Standard Air Ride, 22-1/2" to 29-1/2" Pro-Style Stand-Up Air Ride.
So I think the description you read on 9 inch posts is the seller covering themselves if someone used it upfront or in that real high casting post hole like my boat has over the gas tank area.
And by the way. I see "idiot" Captain's allowing passengers or kids riding up there in the forward seat position or with kids upfront with their feet hanging off the bow while doing 40 mph flying around the lakes. Unfortunately, taking a boating course or needing a license to drive a boat in NY is not mandatory. It should be!
Huron Angler
Re: Pedestals
I've given this a lot of thought too...since my SS came with 4 class "B" bases/posts and two seats. I have two more seats to throw in there and I'm looking at getting the locking posts/bases for my helm and passenger seats.
I went in to West Marine and they didn't even have my older style pin with key post. I might have to order online I guess.
I think it's a safety hazard as my boat came...no class "A" seats posts at all. You don't want your seat swivelling when you are in some great lakes weather.
CBGale2
Re: Pedestals
I wasnt suggesting ridding in a bow mounted spot at 40mph. Thought never crossed my mind. Im setting the boat up with a driver and passenger seat on pedestals and then two more rear seats on boxes facing forward up against the splashwell. I was then going to put a pedistal mount between the two rear seats, that way the passenger can move their seat to the rear for some more room while fishing.
I found some I think will work that are rated for A(passenger). They should be plenty good for what Im planning on doing with them.
