Parts needed 1993 90hp Evinrude v4 croosflow
woodshole
for arson damged engine:<br /><br />-a cowling<br />-electric fuel primer solenoid<br />-VRO replacement fuel pump (I am dumping the vro oil injection)<br />-splash guard (plastic cowling shroud underneath engine)<br />-tilt switch (the one mounted on the starboard outside of the engine)<br />-all hoses for the carburetor, VRO fuel pump, electric fuel primer solenoid<br />-for the bottom carburetor I need minlon float bowl<br />-water indicator hose fitting (the plastic piece exiting the engine) and hose<br />-main positive and negative cables<br />-control box with ignition/trim/wireharness/key<br /><br />if you can help--------------> seanpaddy@hotmail.com<br /><br />yours truly<br />sean
D
DJ
Guest
Re: Parts needed 1993 90hp Evinrude v4 croosflow
woodshole,<br /><br />Check out: www.twincityoutboard.com No sense buying new. Many parts from different years of crossflows will fit.
snapperbait
Sean: Ebay for the cowl and control box... If you could list your location someone might know where you can find used parts that may be avalible in your area... I know a place in my area (see below) where you could most likely get all the parts you need in one trip... ;)
woodshole
I am located in woods hole, MA
Joe Reeves
Woodshole.... Are the battery cables custom length as would be made up when rigging, or are they OMC factory cables. If factory cables, what is the length. I have quite a few new sets left in stock of various lengths.<br /><br />ReevesJ32@aol.com
Hooty
The only thing I see on your list that I have is the float bowl. Email me your address and I'll send it to ya.<br /><br />jehart1@attbi.com<br /><br />c/6<br /><br />Hooty
