Re: Parts and fuel questions
Here's the quick list:<br /><br />1) Disconnect the shift wires next to the engine near the back.<br />2) Remove the back half of the midsection's exhaust shroud. There will be a pile of phillips screws that need to come out. If they're proving to be a hassle, invest in an inexpensive impact screwdriver. The kind you hit with a hammer.<br />3) Remove the access plate on the starboard side of the forward part of the exhaust shroud, and then remove the plate behind it. Snake out the electric shift wires so they're free. Soap helps.<br />4) Unbolt the lower unit and pull it straight down. You may have to force it with wedges if the splines weren't properly greased. Don't worry, the only parts that can break are cheap.<br /><br />Installation is the reverse of removal, but be sure to grease the splines and replace the o-ring on them if it's bad. Also, coat all the screws and bolts with gasket sealer or grease before re-installing. This will keep them from corroding in place.<br /><br />Goop is basically what holds the wires into the lower unit, so be careful like you were advised not to pull hard on them. These engines are among the easiest to wrench, excepting the electric shift lower unit. If you run into troubles, we'll be here to help.
