Simoniz
- Dec 30, 2007
- 247
Is anyone with access to part diagrams able to find out a couple of partnumbers for me please? Ive looked around the internet now for ages without success.
If you follow the pipe from the gear oil reservoir down to the transom, there is a 90 degree elbow connector with a quick release female fitting which fits onto the pipe which then runs through the transom to the other side. I need to find out the part numbers of the 90 degree elbow at the end of the tube and the plastic pipe which runs through the hull (other end of this pipe has the small hose which connects to the check valve on the bellhousing).
Many thanks!
edited to add Alpha 1 Gen 2
Many thanks!
