Part compatibility
bill83
Hello everyone I am just wondering if anyone knows if merc and force parts are compatible. I have a 1990 merc 90hp 3 cylinder but my stator is done, and I was wondering if I could replace it with the stator off a 1990 force 90hp thanks
gm280
Not sure of the compatibility myself, but you could research the two part numbers and see if they inter swap. Sometimes after market parts will offer different engines their parts cover. And if they specify the two different engines, then it would seem that it would work. What is wrong with you present stator and how do you know it is bad? Post some pictures of it and let us see what you see and are working with... JMHO!
bill83
Sorry I'm not at home this weekend so I can't post pictures but I used a multimeter and tested red stator wire to engine ground then green stator wire to engine ground and only got ohm reading on red
