I am having alittle trouble with my starboard transmission. It was rebuilt about one year ago and has probably 40 hours on it. Trans is 3 to 1 ratio. mounted to a crusader 454. year is 1979.<br />problem is failure to shift into forward once in a while. predominantly when it is warmed up. the pressure in neutral is 120 psi and is the same when the gear is engaged either forward or reverse. I found that when it fails to engage forward the pressure drops out needle bounce some and usually will engage in time. immediately after engaging the pressure restores and no trouble until I shift again. (there no problems with reverse works every time oil is good and clean.) why is the pressure dropping out at this point only? and what can be done short of pulling it out again.
