paint formula
miloman
can any one help on this one I need the paint formula or an over the counter color match for a starcraft white sb 16 wb 92 thanks
SpinnerBait_Nut
Re: paint formula
Let's see miloman ol' buddy, if my memory serves me correct, which I doubt at times, a white starcraft is WHITE!!!! :p <br /><br />Sorry, could not resist it. :eek:
Spidybot
Re: paint formula
Thinking about how fast colors change (start fading) while out in the weather, I'd suggest you make a match to a color chart. Paint can be mixed to any color, gelcoats come in a number of standards. Even when doing paint jobs on almost-new cars, the colors are mixed to suit.
jomac
Re: paint formula
miloman- UU's right -If it's an Alu. boat you have, check automotive paint stores in your area most of them now have a scanner that will matchup most colors pretty close(buff a small area) call around to see if any have a scanner, they will need to scan the boat . for gelcoat colors your going to have to settle with something close :) Good luck
