Dhadley,<br /><br />I thought I would post separately regarding my Evinrude.<br /><br />I recently changed my water pump about 5 hours ago and I am not happy with it. Doing installation I crushed the new gasket but used sealer and it looked OK. Water was stronger at the tell tale but not gushing. A separate discussion on water pressure we joined in on suggested it is low pressure system.<br /><br />The mechs who rebuilt my engine said thay had altered the pipes in the head to improve cooling which meant that the outlet from the tell tail would be reduced. I couldn't really understand what they said.<br /><br />Last night I noticed the outlet was barely dripping, even when I revved the engine. When I disconnected one of the piped into the outlet I was just getting air.<br /><br />When I run the engine I get pressurised water being forced out beteen the lower unit and shaft face where the bolts are. Is this normal? I am thinking that maybe I am losing pressure at the pump itself??<br /><br />No real problem to drop the LU again but I need to know what I am looking for and also to understand the workings of the cooling system more.<br /><br />When the engine was running the cyclinders wre not overly hot and the water temp from the outlet was OK too.<br /><br />Pannet, your engine is an 1990? How does your outlet compare?<br /><br />For others, my engine is a 1989 Evinrude VRO (disconnected) 140. I would appreciate comparisons.<br /><br />Thanks<br /><br />NG
