Re: OX66 vs HPDI, Whats the difference?
DFI (HPDI) engines are different than EFI (OX66) engines in that they shoot the gas directly into the cylinder at the appropriate time which makes them much more efficient. EFI motors lose some of the fuel directly to exhaust without burning first. At higher RPMs 2-strokes are quite efficient no matter if they're EFI DFI or Carbureted. It's in the low to midrange where DFIs can save you a lot of gas as opposed to EFIs and Carbureteds. Tests show that DFIs are generally more fuel efficient than 4-strokes as well as superior in performance (the specs are close).<br /><br />As far as repairing, carbureteds are readily repairable by anyone knowlegable. EFIs need a bit more expertise and sophisticated equipment, DFIs more than EFIs. Reliability is about even accross the board when it comes to Yamahas (excellent). Maintenance varies depending on the induction type, but they all need maintenance. Non-carbureteds seem to need a bit less TLC suprisingly.<br /><br />Many very popular lakes already restrict the use of boat motors to 4-strokes and DFI 2-strokes. More will follow. The wave of the future is definately aganst carbs and EFI in 2-strokes.
