My first post and need help. Motor is a 2001 200 H.P Yamaha OX66. Initial problem was surging at low rpm and not reaching top RPM. Changed the O2 and cleaned the barrel. O2 was un clean able. Low rpm surging corrected.
Changed the low pressure pumps.
Compression 135, 135, 130, 130, 130 126
New fuel bulb, engine mounted fuel filter fuel lines .
Cleaned filter on H.P. pump(pretty new 1 year old)
New spark plugs
Pressure at schrader valve(on VST) steady 52PSI
Vacuum at WOT 6 6hg( low at idle about 2hg)
No air bubbles in fuel line
Any help would be appreciated. Ive put alot of hours with my head in the motor and just trying to help an elderly neighbor.
p.,s. Is 52 psi fuel pressure at schrader high?
New spark plugs
