OWNER Of 1999 Yamaha 2 stroke 115 - Water In LU
Hurleyg
I'm the new owner of a 1999 Yamaha 2 stroke 115. I drained the oil in the lower unit today and it came out milky white. I pulled the prop looking for fishing line or rope and found none. I'm reluctant to assume the oil is just old instead of water intrusion. I wasn't looking for water when I removed the lower plug so not sure any water came out first. Suggestions?
robert graham
Not knowing how long since the oil was last changed, maybe refill with fresh oil and run the motor a while and continue checking for water....new washers on drain and vent plugs. If later checks indicate a water/seal leak then a pressure test on lower unit will help identify which seal is leaking....
99yam40
why not just pressure check now that you have it drained to see if it leaks and where
ClassicAQ
I'm not 100% positive, but pretty confident, that if you're gear oil is milky white it's because and only because water has passed by the seals and infiltrated the gear box. Essentially, regardless of how old the gear oil might be, it's color will never turn milky white because of age. It turns milky white only because it's come into contact with H2O.
I don't see any issue with r. graham or 99yam's suggestions. If you don't have the necessary tools to pressure test, go with r. graham's suggestion and refill with new gear oil. Run engine under load. Drain oil. If the new gear oil is milky white....replace seals.
Hurleyg
Thanks for all the inputs. I don't have access to pressure tester so have decided to take it to a certified mechanic. At least you all confirmed it to be water intrusion and I have a leak somewhere in the unit.
QBhoy
Quite likely it?s just the seals at the vent and drain screw. I?d be tempted to replace both with fresh oil and see how she goes.
tommarvin
Ensign
You can get a pressure /vacuum tester at harbor freight tools cheap, then you can test at the end of every season, for the rest of your boating life.
You can use 100% synthetic marine gear lube that's tested with 10% water and it passes independent third party strict testing..
