nautico 19
- Jan 18, 2006
- 19
Have a pair of 1999 50 D tohatsu on a Nautico power cat, both over heat at high rpm cleaned carbs they didn't look bad,no change, changed water inpeller, no help, changed thermostat, no help cleaned carbs again no help. checked fuel lines,ok checked check valve type that threads into tank ok has two 38 gal in hull tanks. Line is 1/2 inch out of tank for four feet changes to 3/8 3 more feet of hose into fuel water filter seperator 3 foot of 5/16 to motors. Too much hose? wrong size? Bad fuel pump????
