OVERHEATING ?????
Bennett
1990 60hp Johnson VRO<br />Just replaced water pump (works good) replaced T-stat (looks alot different) upgraded tell tale and heat sensor. Used heat stick,no 163 degree to be found. I used a 150 heat stick, and melted in back of t-stat housing 175 did not Overheating. Using muffs at idle ???? Thanks
