Intruder 4.3
- Nov 29, 2010
- 19
Hey guys,
I have a 2004 Mercruiser 4.3L MPI (Engine serial number OWOO7177 - model -MCM4.3L MPI) Alpha drive (Drive serial number OL9566Z3) with a closed cooling system installed in a 2004 20' Alumaweld Intruder. Took it out from winter storage today and had the alarm indicator whistling at me. I believe it was over heating and as far as I can tell, the sea water pump is not pumping water through the system.
Once I had it home I hooked up the hose to the muff, and ran the water. The water was not coming out of the out drive. I have 2 Blue drain plugs on the sea water pump. One is for the intake side and the other is for the after pump side. Under garden hose pressure I was getting water out of both of them.
My questions are:
1. What other tests can I perform to isolate this symptom to the sea water pump?
2. If I can determine the pump is in fact the problem, can this pump be rebuilt, if so where can I buy a rebuild kit?
3. Where should the water be exiting the system on my drive? I am thinking through the center of the prop along with the exhaust.
4. When a through hull pump is installed does the out drive impeller still pump water?
5. Am I asking the right questions above?
I did search for this, if this has already been covered I apologize, please post a link.
Any input is helpful
Let me know if additional information is needed.
Thanks!
Chad
My questions are:
Thanks!
Chad
