dennis cudd
- Nov 7, 2002
- 3
i have a 76 233 mercruise in board. the water pump has been changed the impeller has been changed ihave put a new sea pump on and it still runs hot.ihave taken the thermastat out some times you can swtch the motor off and let it sit for a while and start it back up and the boat will run fine for the rest of the day. several weeks during the summer it didnot run hot at all then all of a sudden it started back again. i put it in the shop hoping to get some help. the shop cleaned some rust out of the exhust mainifolds and said that took care of the problem since then it runs hot all the time.he put some clear hoses and said one would bubble up for a while and then clear up. he thinks its, the exhaust manifoldbut doesn't know for sure and i have already spent 400 bucks and still have the same problem and do not want to spend any more unless it is going to be fixed can you give some advise./
