merc 140 pontoon
- Aug 23, 2003
- 129
1974 Merc 140, engine s/n 388...., stern drive s/n 390....<br /><br />Used to overheat only at high rpm, now overheating at all rpm. Overheats very slowly at idle, slowly at 1500 rpm, very quickly above 3000 rpm.<br /><br />I ran a simple test tonight, and have some questions about the results. There is a short hose from the thermostat housing to the manifold. I pulled it from the thermostat housing and tightened it over the end of my garden hose. I then ran fresh water through the manifold, slowly increasing flow until my water faucet was wide open. (Obviously, the engine was off throughout all of this.) I got pretty good flow--not as much as would come out of the hose alone, but maybe half as much, or a little more. I'm wondering about all the places the water came out, though. There were five places:<br /><br />-- Two holes in bottom of housing next to transom (gimbal housing?). When the stern drive was tilted up about halfway through its normal operating range, most of the water ran strongly in two streams from these holes. When tilted all the way down, water dribbled out of these holes. Should I see water out of these holes? I thought the exhaust was supposed to come out the prop, but a lot of my exhaust always comes out of these holes.<br /><br />-- Small hole on starboard side of gear housing. This hole isn't plugged. I don't know if it should be. I've read that this changed over the years. The stern drive s/n is 390***x. There was good flow (considering the hole is very small) when the stern drive was tilted down all the way.<br /><br />-- Gap between prop and gear housing. Some flow out of here when tilted down all the way. A mechanic has mentioned that my prop ventilation problem (2350 rpm with 13" pitch props, 3500 rpm with 17" pitch prop) may be due to this gap being too large, due to an incorrect spacer in front of the prop. He hasn't seen the drive. Should I see water coming out of this gap?<br /><br />-- Prop exhaust port. Good flow (more than half of total flow) when tilted all the way down.<br /><br />Does it sound right to have the water (normally would be exhaust) coming out of these five places?<br /><br />For a closed cooling system (mine is open), Clymer says the fresh water section should be flushed and cleaned with any high-quality automotive cooling system cleaning solution to remove scale, rust, mineral deposits or other contamination. Is it possible to do something similat for an open cooling system? I'm not sure I'd want to recirculate the dirty solution somehow, but would running it through once help somehow? Seems easier than taking everything apart.<br /><br />My game plan is to take the engine circ pump apart and check it, then go to the manifold and riser. The stern drive water pocket keeps eating at me, though.<br /><br />Dumb question(?) - why isn't there a gasket between the stern drive gear housing and drive shaft housing?<br /><br />Thanks.<br /><br />Steve
