Back in May I purchased a 32'1988 Chris Craft Stinger. I had both engines rebuilt (1997 Johnson 225 Loopers) standard rebuild 20 thousands over, with Wiesco pistons at a local marina. After the break in period I noticed both motors were overheating after about 15 mins on plane. I've had them back several times for various fuel related problems each time fixing one thing or another. We decided to removed the VRO and I mix the oil directly to the fuel in the tank. Today he ordered electric fuel pumps stating that they are inexpensive and very reliable and is intending to eliminate the diaphram fuel pump altogether. However, they are still unable to figure out why both motors are overheating. The mnotors have a typical cylinder head temp sending units (one wire) they are attached to gauges which are colored green and red. Both will run hot and sound the horn after about 15 mins of wide open thottle (about 5000-5500)rpm. I have tried to play with the tilt and trim; it seems if the motors are tucked all the way under the temp is high, but not enough to trigger the warning horn, but I loose knots on the top end as a result. usally I run about 40 knots trimmed out. The mechanic who rebuilt the power heads first checked the water pumps, then removed the screens from the lower units and enlarged the water pickup holes. This seemed to help a little but it still overheats. I added water pressure gauges and have 8 psi. Does this seems too low?. By this time I frustrated. I asked if the thermostat could be the culprit, or the head gasket. The mechanic insists that these are not likley candidates. He wants to lower the motors on the Armstrong Bracket 1 inch, stating that he noticed a flucuation in the water pressure gauge during testing, thinking the top water inlet is sucking air. I need some help guys. He said if this does not work he wants to put low water pickup tubes or some sort of bullet on the lower unit with a SS hose to the power head to flow more water at the tune of $300.00 each. Owee. Does anyone have any thing I can suggest or try myself? Is 20 over too much for a looper? And why does the water not "****" it seems to slowly flowout? Should the pumps produce more than 8psi? At what temperature doo the warning horns sound?<br />Thanks for any help...
