I just replaced the impeller on my 1972 35hp chrysler model 354HC, due to a pretty bad overheat. The impeller was ground to bits. I ordered the impeller (sierra part #3084) that supposedly fits my motor. The old impeller had 6 fins, and the new impeller has 10. The new impeller's fins were too long, so I trimmed off the ribs on the end of each fin so it would fit snug into the water pump housing. It seems to be pumping water, but I'm not sure if this will be efficient enough. I took the boat for a test run and it didn't seem to overheat, but it didn't give a steady output of water out of the exhaust either. Sometimes it shoots out like a water hose, other times, it looks like just smoke or steam. I also removed the thermostat cover to find that there was no thermostat in the housing. What do I need to do to make sure that my engine is cooling properly? Is my "trimmed impeller" going to work ok? Shouldn't there be a thermostat inside the housing?
