I posted a while ago about a 1989 mercriuser 4.3 alpha one overheating when idling and at low speeds, but ok when cruising. I was told to check water pump/ impeller in the outdrive. This morining I finally got inside to look at the impeller and it looked fine, no broken fins. I will replace to pump/ impeller but not sure if that is the problem. What else could be causing this motor to overheat?
Scott
Scott
