Martoony33
- Jun 7, 2003
- 6
Greetings to one and all!<br /><br />I own a Honda 4-stroke BF50 S 5 h.p. motor.<br /><br />* It runs very well for about 1.3 hours, then it seems to overheat. The motor stalls and stops. After 5 minutes, you can restart the motor, but it will die if run at lower to idle speeds.<br /><br />* The tell tale is working -- I have a goodly amount of water spritzing messily out of the tell tale, although it doesn't come out in a clean, steady stream (like a fountain figure in a garden).<br /><br />* My assumption is that the impeller is working, because the water volume coming out of the tell tale is decent. <br /><br />Is there such a thing as a thermostat with these units? Could that be the problem, or is something else more likely?<br /><br />Many thanks for the kindness of strangers,
