I finally had a chance today to test the engine temp with an infrared thermometer. I have an 1992 E90TLEND. I cranked it and it ran good then about eight minutes later I heard the temperature warning horn go off. I tested the temperature of the engine and found these results. On the right side of the motor around the sparke plugs it was in the 190 to 200 range. I then went to the other side and the top part around the spark plug was about 240 and the bottom around 210. Did I run this long enough to cause damage? Why would only one side be overheating more than the other? Shouldn't the temperature be around 160 to 180? Like I said in an earlier post, the tell tale is spitting water but it does not seem continous. It has little breaks in the steam. Thanks for the help.
William
William
