Re: overheating on plane
Welcome to iboats jack!!
Could use some more info like boat size, maintenance, drive, but here is some starter stuff. At idle, reved up or not, there is no load . . . load means fuel, fuel means heat. Here are the troubleshooting sections from a Merc Service manual. I assume you have an Alpha drive, so disregard the comments about a belt driven seawater pump. Yours is most likely in the drive.
Engine Overheats (Mechanical)Cause Special Information
1. Engine RPM below specifications at wideopen-
throttle (engine laboring)
1. Damaged or wrong propeller; growth on boat bottom;
false bottom full of water
2. Wrong ignition timing 2. Timing too far advanced or retarded
3. Sticking distributor advance weights
4. Spark plug wires crossed (wrong firing order)
5. Lean fuel mixture 5. Refer to Carburetor Malfunctions in this section
6. Wrong heat range spark plugs
7. Exhaust restriction
8. Valve timing off 8. Jumped timing chain, or improperly installed
9. Blown head gasket(s) 9. A blown head gasket(s) normally cannot be detected
by a compression check. Normally the engine
will run at normal temperature at low RPM,
but will overheat at speeds above 3000 RPM.
Engines that are seawater cooled: Using a
clear plastic hose, look for air bubbles between
seawater pump and engine. If there are no
bubbles present, install clear plastic hose be
tween thermostat housing and manifold(s).If air
bubbles are present at a higher RPM, it is a good
indication there is a blown head gasket.
10. Insufficient lubrication to moving parts of engine 10. Defective oil pump, plugged oil passage, low oil
level
Engine Overheats (Cooling System)
IMPORTANT: The first step is to verify if the engine is
actually overheating or the temperature gauge or
sender is faulty
1. Loose or broken drive belt
IMPORTANT: Best way to test gauge or sender is
to replace them.
2. Seawater shutoff valve partially or fully closed
(if equipped)
3. Clogged or improperly installed sea strainer
4. Loose hose connections between seawater
pickup and seawater pump inlet (models with
belt driven seawater pump only)
4. Pump will suck air. Pump may fail to prime or will
force air bubbles into cooling system.
5. Seawater inlet hose kinked or collapsed
6. Seawater pickup clogged
7. Obstruction on boat bottom causing water
turbulence
7. Obstruction will be in front of seawater pickup,
causing air bubbles to be forced into cooling system
8. Defective thermostat
9. Exhaust elbow water outlet holes plugged
10. Insufficient seawater pump operation 10. Worn pump impeller
11. Obstruction in cooling system such as casting
flash, sand, rust, salt, etc.
11. Refer to water flow diagram for engine type being
serviced
12. Engine circulating pump defective
13. Also refer to Engine Overheats (Mechanical)
