Re: Overheating of 2002 honda 30hp motor
Could be the water pump or thermostat. My bet is on the water pump, but checking the thermostat is easy. It's placed on the left side of the engine, when looking at the engine from behind (where the "30" number is on the hood). Unbolt the circular-shaped housing and remove the thermostat (just pull it out). Screw everything back together and check for water flow. If you got water, the thermostat is broken. If not, replace the impellor.
Replacing the impellor is a tougher job. First get a new one at your dealer. Then, put the engine in reverse and unscrew the gear system (halfway down the tail of the engine is some kind of opening where you can unscrew it when in reverse). Then, unscrew the bolts on the tail of the engine and remove the tail. Refitting is in reverse order, bear in mind that you will need to readjust the gears so that neutral = neutral, reverse = reverse and forward = forward.
Good luck
