This thread is only for the smart ones; that is, if anyone can figure this one out.
I have a 1997 Mercury/Mariner 15 h.p. outboard. 0G522668
I purchased the motor over the winter and was told it ran good. He ran it for about a minute to show me then shut it down.
I went to put it in the water a few days ago and noticed there was no stream of water coming out the cooling hose. I shut it down and took it back home.
I replaced the 120 degree thermostat and it's gaskets. I then replaced the impeller which the old one looked as good as the new one. I then blew air (110 p.s.i.) in the chambers. First up the cooling outlet and it was clear to the thermostat. I then blew air down the thermostat hole and can hear and feel the air coming out the bottom. I then did the same on the little holes at the bottom fo the casing where the water goes in.
I put it all back together, stuck the body in a large bucket and started it up. After the thermostat opened, I onlyu got steam again. No sream fo water coming out the water/cooling exit.
What can be wrong?
HELP!!!
What can be wrong?
HELP!!!
