My 1972 Chrysler 35hp has been running perfect until last week. I took it out, got the impeller intake clogged and burned up the impeller. IT overheated really bad! Smoking like a chimney. I replaced the impeller and now it runs like crap. It seems like it is missing. It will run but it surges every couple of seconds. Don't know if it's a gas problem or what. I know that it is not and electrical issue becuase I've checked both plug wires for spark and it's all good. Plugs are good too. It had been running PERFECT before the overheat. The engine also is still overheating. The impeller and waterpump are in good shape and it seems to be pushing water very well. I also flushed the system with a water hose to check for blockages and found none. Why is it still overheating and running rough? These problems have to be in deirect relation to the bad overheat I would think.
