Overheating mercury sci 700
GA_Boater
Welcome aboard.
Is there a question? What's an "sci"?
Bt Doctur
GA_Boater
Thanks, BT. I swear I saw this was in the outboard section and thought is was a Merc 700. :doh:
alldodge
Need more info.
How is it overheating, at idle, on plane, WOT, or all?
When did it start?
Is this a new to you boat?
Has the impeller been changed?
If there is a sea strainer, is it clean?
Bt Doctur
I think a turbine would have a lot less junk attached to it.
no more stuff bolted to that motor than a typical 5.7 other than the supercharger.
the motor is nothing more than a low compression 502 with a supercharger. on there the heat exchangers, exhaust, fuel system, starter, alternator, exhaust, mounting brackets, etc.
