the boat is a 1992 welcraft wth 5.7 260hp mercruiser with alpha 1 outdrive.
the problem is the boat overheats when you slow down from cruising speed the alarm starts going off and tempature spikes to 180 degrees. replaced impeller,an thermostat bfore season .the boat only over heats when you go from cruising speed to idle. any information would be greatly appreciated
thanks
rich
thanks
rich
