Re: Overheating ,I broke down took to shop
No, No, No,<br /><br /><br />15-20 psi is not too high at WOT, it is possibly too high at 2500-3000 like you originally posted, that is when the poppet valve should open... At WOT you should see 20-25psi... If you are getting 30psi, that is too high and leads me to believe that the poppet valve is not opening properly...<br />If the poppet is not opening at the proper rpm, your water flow will be restricted to circulate through the heads to cool them properly.... Hence, that is why they call the poppet the "pressure relief valve"... Pull that baby out and replace the entire assembly, it's a cheap deal...
