FreeBeeTony
- May 15, 2002
- 3,997
While out fishing today, I started to hear a noise coming from the engine (165 Mercruiser IL6). I opened the engine cover to listen better and noticed that the hose coming from my H/E (FWC) going to the circulating pump was collapsing! When I backed off the throttle the hose regained its shape. Could this be a clue to my overheating problem? It only gets hot when running around 3000RPM. And I am wondering if the noise I was hearing is the circulating pump.<br /><br />Another question: the return of the raw water going to the elbow is going to a "barb" installed into the elbow. The hose is 3/4" ID. Seems like it would be nice to use a bigger ID hose for less restriction. Are there any bigger "barbs" available that would accept a larger hose and still fit into the elbow?
