williamtii
- Jun 20, 2017
- 15
Hello All,
The boat has been running great all year so far, until yesterday.......
It started fine, putted out of the river 10-15min fine. Then after about 3min on plane the alarm goes off so I shut off the engine.
It has plenty of oil and a strong pee-pee stream so I let it sit awhile and restarted. Fired up fine so we tried again and after 3-4min at speed the alarm went off again. After some fiddling I found I could run up to about 3500rpm no problem but around 4K would set the alarm off.
I have heard the alarm for Low Oil plenty of times as this is the kind you need to add 2-Stroke Oil to the reservoir. The other time seaweed had clogged the intakes and set the alarm off.
My two thoughts are that it could be cooling, perhaps if the impeller is worn and causing cavitation above 4000rpm.
Or 2, that oil is not getting to the motor despite plenty being in the reservoir. Anyone have an idea of what the issue could be? I don't want to try running it again if its not getting oil !
Thanks,
-William
Thanks,
-William
