I have a 1975 9.9 evinrude, install new water pump assembly. started it up could see small amount of water discharge till it warmed up and overheated. Could this be a stuck t-stat or a water passage problem. I pulled the lower unit again and checked where the tube slips in the grommet, and it looked good restarted same problem. Could a head gasket do this? It has 70 psi both cyl cold. Thanks for any insight!
