New to Boating<br /><br />I try and run engine once a week for 10 minutes to charge the batteries and circulate the oil during the winter here in Washington. However, today after placing water muffs over the intakes on the out drive and starting the engine, no water was being expelled form the exhaust exchange at the bottom of transom. So of course the temperature rose over 180 degrees. So I have three questions. First, how is water being sucked from the intakes on the out drive through the exhaust system? Second, this engine is fresh water-cooled but requires heat exchange from water coming in the out drive, how does this work? Third, I don’t have the out drive all the way down, it’s about half way down when I run the boat out of the water, is this possibly the root of my problem? I’m thinking of taking the boat to the lake and running in the water to see if the problem persist. If it still overheats what should I check for? <br />
